Old 02-09-2012, 05:17 AM   #1
Bigsmoothlee
Unless you plan on tracking your car, dont install solid or semi solid mounts.
On the good side, if you do install upgraded mounts, youll get very little transmission movement and slightly better handling on/off the throttle.
On the bad side, you will have vibrations transmitted to the chassis that the original mounts absorbed.... which, down the line can cause far more damage
Bigsmoothlee is offline   Reply With Quote
