Old 02-08-2012, 12:33 PM   #12
onaFLYer
Originally Posted by jaykay View Post
What year is your car? If you have a 2000 you need to ensure that you have the right sensor installed. There were updates to the sensor which require updates the DME from Porsche. You may have mismatch between sensor and software
it's a 2002, and the stamped part number matched. Even had the updated version, 125 01 on the end. Still waiting for my hoses to show up.....
Originally it wouldn't run at all with my MAF plugged in, well it wouldn't accept any throttle. So I unplugged it and it ran OK, which led me to believe the sensor was bad. Apparently it just needed some time to cycle through, since everything was unplugged, batt, DME, all sensors. Now it runs fine when warm, but the vacuum leak is keeping the sec evap from cycling and it won't pass smog. Even w/o a cel. It needs to go through the whole cycle starting cold, at least according to Bentleys version of the "drive cycle".
we'll see.
onaFLYer is offline   Reply With Quote
