Instead of replacing the headlight switch, you might want to try the cheap fix first. Clean it with electrical cleaner. I think the trick is to spray it as much as you can and then SHAKE IT FOR A FEW MINUTES. Attach the small straw to the spray can tip so you can force the cleaner detergent into the switch.
