Old 10-07-2005, 06:38 PM   #2
deliriousga
deliriousga's Avatar
http://www.theschillings.com Click on the Boxster then Maintenance DIY. I don't have the torque values for the drain plug or the filter can so if somebody has them please let me know so I can add them.
When you do the oil change, you should also check the joints on in the convertible top and lube them with white lithium grease (use a Q-tip to apply the grease).
1966 Wife White/Brown Top
