Spec Boxster with fresh motor
Its with great sadness that Im doing this but Im selling my Spec Box. Below is the build sheet along with a short list of spares that will go with the car. Additional pictures and more extensive list of spares available upon request.
Asking price is $30,500 OBO for the car and spares or $35K including enclosed trailer
NEW REBUILT MOTOR!!!
Engine and Transmission
K&N Air Filter
New Oil Seperator 996 107 023 04
Semi solid engine Mount
Semi solid transmission Mount
AASE Lightweight Aluminum Flywheel
Sachs sport Clutch Kit
New throw out bearing
Under Drive Pulley
Spark Plug Set 999 170 201 90
AC delete Muli-rib Belt 996 102 151 66
Custom Grand Am style radiators
LN Engineering Spin-on Oil Filter Adaptor
LN Engineering replacment IMS
Porsche updated RMS
Factory X51 oil sump
2QT Accusump w/electric valve
Mobile One Oil qt
Delvac Gear Lube liter
Custom Seatrab trans cooler w/electric pump
Braille Light weight battery
Shifter Cables
Shifter Risers
Air Mass Flow Meter
New Porsche Coolant Expansion Tank 996 106 147 08
Suspension/Wheels
Bilstein PSS9 Kit 986/986S
Eibach Springs 450 lbs, Front
Eibach Springs 500 lbs, Rear
Hyperco Helper Springs, Front
Hyperco Helper Springs, Rear
Spring adaptor main-to-helper, 2.5" front and rear
Wheel bearing kit, rear
Wheel bearing kit, front
Porsche GT3 Lower control arm kit, front
Porsche GT3 Lower control arm kit, rear
Lower control arm shim rear, 8 mm
Lower control arm shim rear, 2 mm
Lower control arm shim front, 4 mm
Lower control arm shim front, 8 mm
Tarret Front sway bar and drop link kit
Tarret Rear sway bar and drop link kit
Toyo Tires with Shipping and Mount and Balance
Alignment and Corner Balance
Brake System
Pagid Brake Pads, Front
Pagid Brake Pads, Rear
Powerslot Brake Rotors,Rear
Powerslot Brake Rotors, Front
Stainless Brake Hose Set
Brake fluid SRF Liter
Safety
Full Roll Cage Installed with Paint
Master Cut-off Switch 4430 Installed
Carbon Fiber Dash w/ AC covers
Carbon Fiber Dash with A/C Vent Cover
SCCA Off Decal 3356
SPA Pull Cable 6 ft, Internal
SPA Pull Cable 6 ft, External
SPA Fire System, 4.0 Liter Mechanical
Team Tech 6 Point Harness, Rotary Buckle
Window Net
Window Net Frame Kit
Heim joint
Custom tow hooks
Cobra Imola S seat
Light weight custom Cobra seat mounts w/slider
MOMO Steering Wheel Adaptor Hub
DAS Steering Wheel Quick Release
Longacre Wide Angle Mirror
AiM Micron 3 XL Gold data acquisition system with dash and beacon
Body
Custom Fiberglass Hardtop with paint
Camlock -6
Camlock Floating Receptical
Heat and AC removal
Heater Core Delete Panel
Steering Lock Delete
Lightweight Door Procedure
Cup Car Wiper Modification
New Windshield
Universal Windshield Seal and 3M Window weld
Rear Wing Modification
Hillman Locking Pin for Wing
Hardtop Pin Assembly Set
Custom Stainless Exhaust
Spares:
2 stock radiators
Additional full set of Boxster twists with good Toyos mounted
Transmission
