Old 02-01-2012, 01:56 PM   #3
dghii
Check your RPM's when you feel the buzzing...could be your motor mount. Most folks feel it with the motor turning around 2500 rpm (give or take a few hundred). If your car has higher miles and you don't know when the mount was changed last, it may very welll be cracked.
I had a 98 base last fall that felt like it had rough idle (and roughness around 2800 rpm). I replace the motor mount that was definately torn and it felt like driving a new car!
I have also ordered a mount for my 2000S (100K miles). The car has a slightly rough idle (but rock solid tach display). I am confident that the new mount will remove the roughness I feel.
