Originally Posted by spine911
Yep, the most convenient way to get you into an accident.  Last thing i need is some crazy idiot messing around with the traffic lights.
Hi,
You're missing the point. This device turns the light Green and the Crosstraffic light Red, through the regular, albeit sped up cycle. When the sensor gets the signal, it either holds the light Green, if it was already, or it immediately turns the Crosstraffic light to Yellow, then Red and the light on your street Green, just as usual except it breaks the normal rhythm. Also, the sensor on the Semaphore also has an indicator light to tell you that it
has received the signal and is cycling the light to Green, letting you know it's safe to proceed. No way it'll cause an accident, it may inconvenience you and make you wait if your in the Crosstraffic...
Happy Motoring!...Jim'99
