Old 01-31-2012, 12:33 PM   #6
jcb986
jcb986's Avatar
I chased my leak in the main drain in the foam liner. The drain is a little funnel attaching to a tube that drains water down through the body cavity and comes out in front the the rear wheel. Under normal rains, no problem, heavy down pours then I had water under the seat. Easy check is to open your top to service position and pour about a quart of water in the foam tray. Look behind the drivers seat feel where the panel meets the floor...you may feel or see it draining here into the car.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
