Originally Posted by Homeboy981
Also, most of my plastic on the bottom is not salvageable. Anyone know where I can pick up all those plastic bits cheap? Thanks again!
Since you are in TX, these guys are probably the closest to you.
Oklahoma Foreign- Used Porsche Parts. From early to late models, 356, 914, 911, 930, 944, 928, 968, 993 & boxsters.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
