FS: 97-99 Chassis Wiring harness -17lbs
We take a good used chassis harness and trunk harness and remove EVERYTHING that is not needed to make the car run and drive (you can tell us what you want left in the harness)
We always leave:
ABS
Brake lights
Immob
Dash wiring for gauges
Ignition Switch
Typical Boxster wiring harnesses start out at 32-35lbs depending on the options!! We easily remove 15-17lbs depending on what you want left in place.
The harnesses are bench tested prior to shipping (all the way through key-on-start)
This is done on an exchange basis (we always have a harness done)
The harness is wrapped in an easy to deal with mesh braid that is split (in case you want to add something later)
We move the immob to the area behind the passenger air bag cover (keeps it from getting wet)
All work is performed in house with Porsche tools by an electrical engineer
$1200 service plus shipping. Phone support is included in case you need help with removal or install.
