Old 01-25-2012, 09:05 AM   #17
TerryT
2002 Boxster
Hi, I am using AWA.. and am paying installments.
This is what is covered.
Engine: Cylinder block and cylinder heads and all internally lubricated parts; turbocharger; supercharger; harmonic balancer; timing gear, chain and belt; and water pump. Seals and gaskets.
Transmission: Transmission case and all internally lubricated parts; torque converter; flywheel/flex plate; and vacuum modulator. Seals and gaskets.
Driver Axle(s): Drive axle housing and all internally lubricated parts; locking hubs; drive shafts; universal joints; and constant velocity joints Seals and gaskets.
Transfer Case: Transfer case and all internally Lubricated Parts. Seals and gaskets.
Air Conditioning/Heating: Condenser; compressor; compressor clutch; and evaporator. Accumulator; dryer; expansion valve; condensor fan; and condensor fan motor.
Electrical: Alternator/generator; A/C blower motor; starter motor; starter solenoid; and starter drive. Horns; windshield wiper motors; windshield washer pump; power antenna motor; power window motors; window
regulators; power door lock actuators; power trunk release; and all manually operated switches..
Fuel System: Fuel delivery pump; fuel injection pump; metal fuel lines; fuel pressure regulator; fuel sending unit; and fuel gauge.
Cooling System: Cooling fan; cooling fan motor; and fan clutch.
TerryT is offline   Reply With Quote
