Old 01-24-2012, 11:05 AM   #8
Gilles
: PROBLEM SOLVED! It was VERY EASY. The steering wheel nut had come loose.
Homeboy,
Wow, if the steering wheel moved up +/- one 1" because the nut was loose...!
This means that you could (literally) ended up with the steering wheel on your hand, or much worse (on your neck)...
Thanks God nothing bad happen
