Gents,
In this middle of this large project and ready to tackle the oil issue. I've cleaned up the underbody, replaced water pump, replaced thermostat, and replaced engine mount.
I'm not real sure how to replace the oil filler tube. The one I ordered is the one on top that is visible on top of the engine. Will running the car stationary cause it to leak oil as well or do I have to go drive it to see if it still leaks before replacing?
Will I have to do anything with the coolant tank/coolant to do this replacement? Someone mentioned it was just a clamp that could be loose. Where would I find this clamp? I haven't put the drained coolant back in yet, but wanted to make sure I wouldn't have to redrain it to do the oil tube.
Thanks guys!
