Old 01-22-2012, 06:10 AM   #1
LAP1DOUG
LAP1DOUG's Avatar
Header bolts - don't be afraid
So, after reading many tales of woe on this and other formus, I was really concerned about trying to remove my header bolts.
I had sprayed them with Liquid Wrench several times over the last couple of weeks while the car is up in the air for Winter project work. I then read about mixing acetone with auto transmission fluid, which is supposed to make a penetrating fluid that is better than anything you can buy at the store according to some test data I found, so I did that too.
The day finally came yesterday, so I heated up the head (not the bolts) with a propane torch, thinking it was better to expand the aluminum than to heat and expand the steel bolts, then I sprayed one more time with acetone/atf.
All 12 bolts came out as smooth silk.:dance:
I don't know if some of my steps were overkill, but I hope this may save someone else another tale of woe. Oh - be carefull of the acetone around hot surfaces, and make sure you don't get anything too hot that has been or will be sprayed with that stuff.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
