Old 01-14-2012, 05:57 PM   #3
ferrytrip1
Thanks Maurice
Last night after eading posts on windows standardization I tried that many times.
When in the car with roof up and windows closed when I open the drivers from the inside door the window drops as it should and stays in that position when I shut the door. Seems OK
From the outside when I lift the handle the window drops that 1/2 inch, so that makes me think the handle m/s is ok. However as soon as I let go of the handle (still with the door open) it rises again. So this makes the window to high to located under the roof when it closes. To make it fit I close the door and lift the handle to drop the window then release. Could it be related to the door open switch or as you say the door lock m/s
On the passenger door the window drops when I lift the handle, but only a few mm and it catches on the roof - less of a problem bu not right.
Thanks for the help
Simon
ferrytrip1 is offline   Reply With Quote
