do you see any problems fitting the 997 plenum due to the larger size of the part ? are you going to use the larger 997 throttle body ? i was looking at the 101 boxster book and in the 3.4 swap he used standard 3" pvc pipe and a pvc elbow would you consider using that for your piping ? do you still think the major air restriction in the system is still the throttle body and tee plenum ? Sorry for all the questions i'm just trying to put a game plan together.
