Old 01-14-2012, 11:19 AM   #6
jaykay
jaykay's Avatar
thread killah ...
anyways, an update. plenum and bits arrived and able to confirm that the couplers will be 3.75" to 3.5" and readily available at siliconeintakes.com. the aos hose will reach ok and the connector will mate to the plenum; may need to get some heat on the hose to reform it once installed. still waiting on the throttle body, and have found a source for flexible 3" silicone ducting to connect to the maf housing.
Nice work. I take it you are sticking with the stock airbox??
The 997 plenum or perhaps we should call it flow divider points the wrong way when you put it in. I hope get a nice radius on the intake tube to smooth out the change in direction!
I am still thinking about the Cayman tee as a result of your post. It sure is shaped nicely especially if you put in the airbox. It looks like it is split down its length and as you mentioned has another flap to actuate. Not sure whether this just requires a vacum line teed off for it or it just flaps. Have a look here.
986 00S
