Old 01-13-2012, 10:19 PM   #8
Topless
Track rat
Topless's Avatar
Originally Posted by stateofidleness View Post
what are the hoses exactly? and what does the lower tstat actually do?
Coolant hoses. They are 11yrs old and you will have to torque on them pretty good to get them off and replace the water pump. Adding fresh hoses is a no-brainer. The T Stat is right there in the same spot, also 11 yrs old, and the original one is set too high (180F) and of crappy design. The LN 160F T-stat is a much more robust design and will allow your car to run cooler which saves fuel, protects your oil temps and engine, and gives you a little better cooling efficiency with more water flow.
While you are in there and the car is up in the air, coolant drained, might as well take care of a few parts on the common Boxster hit list. You will be glad you did.
