thread killah ...
anyways, an update. plenum and bits arrived and able to confirm that the couplers will be 3.75" to 3.25" (edit to fix a mis-measure) and readily available at siliconeintakes.com. the aos hose will reach ok and the connector will mate to the plenum; may need to get some heat on the hose to reform it once installed. still waiting on the throttle body, and have found a source for flexible 3" silicone ducting to connect to the maf housing.
