Originally Posted by Saudin801
Can you clarify more on the O2 sensor issue?
Also, what's different about these headers from the stock ones, diameter?
The Primary Pipings is 42mm And merged to 49mm Collector.
The driver side Header on one of the O2 sensor Bung are welded on wrong position (the one toward the flange section) With O2 sensor installed the sensor is about 1.5" above the ground with stock suspension
Will need Re-Welding the bung for correction.
