Old 10-02-2005, 03:44 PM   #4
deliriousga
deliriousga's Avatar
[QUOTE=insite]carefull. usually the lumen / candella rating is drivin by current. if you put a much higher wattage incandescent bulb in the car, you could roast your wiring.QUOTE]
In addition to this, if you get too much heat in there you can crack your light covers. I'm with insite on the litronics if you have the $$$ or use the Silver Star if you just want to spend $40. We went to Silver Star and they are much whiter and brighter, but they won't harm the system.
Whatever you do, be wary about aftermarket kits unless you know someone who has used it and not had any problems for a month or more. There are several thrown-together kits for the 928 and I have seen several people who had cracked lenses or worse from the kit. At $400+/lense, it's an expensive lesson to learn.
1966 Wife White/Brown Top
