Originally Posted by Bmod986
If you have a picture from the side of te car showing the space between the windshield and the front of the top that would be great. Thanks again.
i don't have a full side view, but here's the side view nearer the window. and my roll bars were not removed. i guess it was just the angle...
I saw a pic of a glass top folded vertically up against the roll bar, which i tried to do but failed. Im guessing that the gahh top glass is a bit bigger.
actually the glass on the 2003+ is a little larger than the GAHH, but there's an extra rib in the top that allows it to fold up that cars before 2003 do not have. that's why some people replace the top with a top from a 2003+ to get the extra rip, instead of go with the GAHH top.
Originally Posted by 2003S
Is the Gahh window larger than the '03 stock? Mine fits nicely if you out the too side of the window down behind the rollbars, and use the attached strap (basically a bungee) to hold it by wrapping to the drivers side corner of the top. Basically, it sits vertically behind the roll bar.
see above, but no, the glass is smaller than the '03 however the extra rib allows it to fold up. additionally, since 03 had the glass, porsche added the "strap" which older cars do not have.
