so if i understand you correctly, an alignment of the rear suspension should be done every time this plate is removed?
No no, you can take it on or off as long as you don't loosen or move the cross member. If you can't get it back on with a similar effort as when taken off something has moved.
If you drop the car or drive around with it off all bet are off on you alignment spec.
