Old 01-05-2012, 03:27 PM   #13
onaFLYer
so if i understand you correctly, an alignment of the rear suspension should be done every time this plate is removed?
Also what is exactly the black cross member you are referring to, do you mean the sway bar?
It's the black bar that connects the suspension uprights together, and the front of that pan bolts to it, IIRC. I hope to be putting that back together on mine this weekend after 4 months apart.
onaFLYer is offline   Reply With Quote
