Old 10-01-2005, 06:14 AM   #7
MNBoxster
Originally Posted by Kinesis 996
Thanks for the info but why do i need the spacers for the rear? Wouldn't it make the wheel stick out of the fenders?
Hi,
The short answer is - YES! - Depending upon how thick a spacer you use.
Without the proper sized spacer, the inside of the Tire/Wheel will contact some of the Suspension and Brake Components, such as the Handbrake Cables - very bad.
The Maximum Allowable Spacer size - 17mm could be tied to the fact that you need Wheel Bolts which are also 17mm longer than the stock Wheel Bolts. Hope this helps...
Happy Motoring!...Jim'99
