Old 01-04-2012, 09:20 PM   #29
Brad Roberts
Brad Roberts's Avatar
Super easy to put in. Put a light coat of grease on the rubber boot..... and push from the back of the slave with a semi long pry bar. I nail it in 5 seconds. It will sit there without the bolt in it (sits in the recess) The rubber boot at the front of it is what slows you down/stops you. It needs to slide and not be dry.
B
Brad Roberts is offline   Reply With Quote
