Have you checked that the rear wheel speed sensors and the brake wear sensor are hooked up?
Also did the car have a firm pedal when you took delivery or did it have the long travel you now note. Even with air in the ABS circuit you should be able to get a firm pedal since the valves close off that part of the system when ABS is not activated.
There is a non PIWIS or Durametric way to bleed the ABS pump but the system needs to be functional. Bleed, go out and activate ABS, repeat a few times. Not the fastest way but it works.
