Old 01-02-2012, 10:21 PM   #4
nieuwhzn
nieuwhzn's Avatar
Ah sorry, now I understand.
The wires are not glued to the cone but to the wire ends of the coil that is suspended inside of the permanent magnet. Could also be that the coil wires are just fed out from the cone to the frame. Usually there is some black goop applied on the wires where they run over the cone.
Sounds like your wire just broke where it comes off the cone.
If you have plenty of time then you can try to scrape off the black stuff and see if you can reattach the wire somehow (probably conducting glue). Personally I would just buy another speaker.
nieuwhzn is offline   Reply With Quote
