Not to be a party pooper, but; if your slave is not already bolted onto the transmission you may of wished you had done that later when you try to get it into place. At least that was my experience. I ended up loosening the tranny and letting it tilt down a wee bit to line up the slave cylinder holes. Small hands would of helped also but mine are not. Good Luck.
