Old 01-01-2012, 03:21 PM   #20
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by feelyx View Post
I think I found the double wide ceramic bearing.....
MR5204C-2RS/C3 NB2 | Boca Bearings - Boca Raton, FL
The double row that came out of mine had the following measurements:
24mm deep
48mm total diameter
21mm inner race diameter
Note - The new bearing had to be less then 20mm because the spiroclip is put in after the bearing goes in where as the original has the clip groove on the bearing it's self.
Measuring to just the grove on the depth is 20mm.
Hope this helps. You can make more accurate measurements once you get it. I'm keeping it in one piece so the grease can be analyzed.
