Old 01-01-2012, 01:14 PM   #2
MaxD
That really doesn't sound like a problem (oil in the tube).
You are on the right track replacing the plastic tubing parts. It took me a while to track down a crankcase air leak on my 98 (rough idle). Turned out there was a crack in the dipstick tube that only showed itself by leaking a few drops of oil after a track day. Replaced that then found out my AOS was bad. When replacing the AOS the original tube to the throttle body shattered while removing it.
MaxD is offline   Reply With Quote
