Old 01-01-2012, 07:05 AM   #21
stephen wilson
I would loosen the clutch pressure plate and realign the disc. I've had this happen when the disc isn't perfectly centered, even using an alignment tool. Also, DO NOT try and pull up the gap with the mounting bolts, you'll break whatever is interferring.
