Old 12-29-2011, 10:52 AM   #1
Bala
yes. used an eyephone to record. held it close to the vent so its clear.
Anyway i did not touch the gas pedal at all. the idle just smoothens out. after the 30 seconds the idle was little over 1000 rpm. when it warms up it stay around 700ish. i confirmed that thru Durametric as well.
there is a small vacuum tube that connects to the cross tube boot behind the tube where the throttle body is. the hole that this vac tube connects into was slightly cracked. seems like a tight fit to me but wondering if that has anything to do with this.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
