Skeefy,
I have the disconnect plug right behind the passenger seat. The wiring looks stock but the speakers are aftermarket. I tried again and it looks like its working but the left side is way too low. The right is ok but overall the level shuld be high when you fade the stereo to the back. The back of the radio has only one plug connected that is stock. Of course i added the ipod connector later. The amp wiring was molested with by the PO for the set that was installed earlier. I did a reconnectof them. Maybe i have to go back and check the wiring.
Question for you is dont the rear speakers with the boxes come as stock all wired up? Mine is a 6x40w amp if that explain anything.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
