Old 12-28-2011, 02:03 PM   #12
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by MaizeNBlueBoxster View Post
Do you need to start with the Revere Copper Cleaner or will the Flitz Polish suffice for the whole job? Wasn't sure if you used the Revere CC because you needed to or because you just had it laying around the garage.
Thanks - Go Blue!
Well I did have it laying around. I started with it because I wanted something to get it initially close and didn't want to use a lot of my Flitz (I need it for a friends wheels). The Revere was the last of 5 I tried and was shocked it worked. The Flitz though is really good and can be used for the whole job...and with any buffing device (even one of those at Walmart that go on a drill) would work great...buffing again is the key to the shine. If you are leaving it on the car then the buffer on a drill would work great i would think.
Mine was actually already removed...clutch/rms/ims/oil fill tube/and ASO while in there.
