Old 12-26-2011, 08:11 PM   #3
Gilles
Originally Posted by harryrcb View Post
take off the left front wheel and the under panels - the hose runs from the steering rack to the center of the car where it has a quick diconnects. the rack end has a bolt to hold both pressure lines and return lines, . there are several line holder that you will have to remove as well. dealere price is around 120 for the hose part number depends on your year 996 347 449 06 up to 01 and 996 347 449 09 from 02 on here is a parts dealer link PORSCHE PARTS & ACCESSORIES
Or if you can find a local hosemaker take the hose to him to see if he can repair it.
Harry,
I removed all the panels and found the two "quick disconnects" for the return and the pressure side.
These quick disconnects have a small plastic ring (black on the return hose), how do you open these connectors? I am worry about breaking the plastic ring, do you have to remove the plastic ring and then unscrew the connector using a wrench on each side? These plastic rings can be rotated on the connector
BTW, thanks a lot for the link for the spare hose, my car is a CS07 and with the part number I got from the PET I was able to find it, however the return hose costs $199, and the pressure hose costs about $150...
After removing the hoses, I will take them both to a hose fabricator, hopefully they can weld a AN fitting into the metal pipe and use a hydraulic approved hose, if this is doable, then I will already have the AN fittings to add a small cooler on the return hose, (better and cheaper than buying two OEM hoses).
Of course I first I have to remove them without breaking or damaging the quick disconnect...
Gilles is offline   Reply With Quote
