Old 12-26-2011, 07:14 PM   #2
harryrcb
Crazy Austrian
harryrcb's Avatar
after inspecting the source for a hydraulic leak on the power steering I found that the low pressure (return) hose was leaking at the fitting where the flexible hose meets the metal hose behind the front wheel this is a crimped connector.
Does some knows how hard is to replace this hose?
I believe that this hose is the one with the 'snake oil cooler' that runs to the rear of the car and connects with another flexible hose leading to the pump.
Somehow I think that this will be an expensive repair... :ah: (only on the parts)
take off the left front wheel and the under panels - the hose runs from the steering rack to the center of the car where it has a quick diconnects. the rack end has a bolt to hold both pressure lines and return lines, . there are several line holder that you will have to remove as well. dealere price is around 120 for the hose part number depends on your year 996 347 449 06 up to 01 and 996 347 449 09 from 02 on here is a parts dealer link http://www.porschepartsnationwide.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=215504
Or if you can find a local hosemaker take the hose to him to see if he can repair it.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
