Old 12-26-2011, 04:37 PM   #1
Bala
Got the MAP mounted. The bass vibration is somewhat reduced after I used the manual to adjust the stereo settings. Becker tech says I probably have 4 ohm speakers and the unit supports only 2 ohms and that could be the issue. Need to pull out the door speakers and test.
Still FADE-to-back does not put out any music in the rear box speakers. It was working before. Any advice?
How do you program the DSP thingy? It's not on the CDR manual?
Hooked up iWireP iPoD connector and it works great.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
