Old 12-25-2011, 03:20 PM   #3
Steve Tinker
Steve Tinker's Avatar
Sounds like your accessory belt / tensioner / idler rollers / water pump could be the cause.
Or it could be your AOS failing....
The easiest wat to check the accessories is to remove the belt and run the engine for no more than 30 - 40 seconds. If the noise goes away, closer inspections of the tensioning / idler roller bearings or water pump is in order.
Driving with a problem with any of the above is not a good idea.
Re the AOS, remove the oil fill screw cap and see if there is a suction - if the cap is difficult to remove, the AOS is failing.
2001 MV Agusta F4.
