Old 12-22-2011, 08:09 AM   #10
Eric G
Theoretical propagandist
Eric G's Avatar
A quick alternative that you could do is take a socket and and grind down all but the insert portions you need to remove the socket. This is a common trick used for removing main engine frame bolts on Hayabusa's when dropping the engine. They work well when you can't find or get the sockets from Suzuki.
Here is what I am talking about...and good luck:
