Old 12-22-2011, 02:03 AM   #5
Spinnaker
Spinnaker's Avatar
Looks like you are caught in a real bind.
If this were my car and problem, I would probably try this next, since you have already tried to get a replacement key without success.
I would make, or in your case, have someone make a steel sleeve that fits tightly around the broken security key. Make sure the outside diameter will fit into the wheel opening. Squeeze the broken key together and press the sleeve over it. It might work long enough to get the lugs off.
You are correct about the serial numbers, I could not find one on mine either.
If it is any satisfaction, you got me off my butt and I bought 4 new regular lugs to replace mine. Been meaning to do this for a long time, but never got around to it.
It is too bad you are so far away from me. I could make a sleeve and send it to you, but by the time it got to you and through customs, I'm sure it wouldl be springtime. Look up a local machine shop, they will be able to make this very easily for you.
Good luck and let us know how it comes out.
