Old 12-20-2011, 07:43 PM   #27
Kroggers
Originally Posted by Brad Roberts View Post
No need to block it off. Just disconnect the plug going to the gray solenoid hanging on the side of the intake plenum. Leave the vacuum lines on the solenoid, but disconnect the electrical connector. This will keep the valve from opening and nothing will come out or go into that black rubber tube. It will come off soon!!
You can easily install those flat plates and remove everything by pulling your IPD piece back out
B
OK, you got me - what grey solenoid? Do you have a picture to help me out here? If the solenoid is disconnected, can I then also remove it?
Aha, I was going to pull the IPD to one side to see if I got access. Will do that then
Back onto the original subject - the charcoal canister. I am trying to identify where the breather line from the top of the tank goes. On the top of the fuel level sender there is 3 lines:
1. Fuel send
2. Fuel return
3. Breather - where is the other end of this line?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
