Old 12-20-2011, 12:49 PM   #26
Brad Roberts
Brad Roberts's Avatar
No need to block it off. Just disconnect the plug going to the gray solenoid hanging on the side of the intake plenum. Leave the vacuum lines on the solenoid, but disconnect the electrical connector. This will keep the valve from opening and nothing will come out or go into that black rubber tube. It will come off soon!!
You can easily install those flat plates and remove everything by pulling your IPD piece back out
B
Brad Roberts is offline   Reply With Quote
