Old 12-20-2011, 04:46 AM   #7
JFP in PA
Choose the right maintainer for your battery. A lead acid battery benefits from sulfation protection. An AGM or Gel Cel battery works best with a more gentle charge at slightly lower voltage.
AGM batteries require slightly higher charging voltage than conventional flooded batteries, but are relatively immune to current rates. The can also suffer sulfation. Gel cels require lower current rates to prevent gas bubbles from forming and disrupting the gel while being charged.
Always be sure any maintainer is correct for the type of battery you are using; better units (like the Ctek) have settings for different types of batteries....
