Looking-for-answers bump!
Questions:
1. How do you secure the amp to the body? The bottom sits on the 2 clip mount just above the spare but where the top two go the holes are empty. Suspecting PO took it out. Does it have one of those rubber mounts that you screw into? Where can I get them as my pollen filter top cover also needs one.
2. Where does the antenna connect to? Looks like a wire needs to be put around the circular bolt in the back. Couldn't see any wire though.
Thanks.
