I assume you upgraded the stereo system but kept the stock Bose speakers? I have a Bose amp that I pulled out of my car but it features the MOST system that connects to the deck using a fiber optic system. If you are not using the original deck, it will not work with this amp. I upgraded the deck in my car because it died, and to solve the amp problem I used 2 new amps to run the system. I believe one was a 4 Channel and one a single Channel. You just need to be careful to buy 2 ohm amps, not the standard 4 ohm units. I've read the existing Bose speakers are mostly 2 ohm. I haven't had any problems this year with the setup and it sounds pretty good. Though they say the existing Bose speakers aren't the greatest either.
