Thread: Front Sway Bar?
Old 12-16-2011, 11:54 AM   #15
Brad Roberts
Brad Roberts's Avatar
The stock ones won't work either.. all the aftermarket links are based on these!!
Run the LSD with one link removed and zip tied up to the toe link (they move at the same rate) and test the car without the rear bar. LSD's inherently induce understeer that has to be dialed out. I leave the nut on the floating drop link and run the car for a session with the bar disconnected, then quickly reconnect it for the next session for side by side comparison.
The rear links being sold are a compromise.
B
Brad Roberts is offline   Reply With Quote
