Thank you both, but it didn't work. I did swap fuses with the spare, but will pick up a pack at the store and replace both of them that deal with illumination of instruments and see if that's the problem. I just did a visual inspection on the fuses and they look fine - but I know they can be bad and not appear to be. The wierd thing is that the guages work, it's just like someone dimmed them all the way down. It's under warranty for 2 more weeks, so I'm going to make an appt. and see what the stealership can do if the fuse replacements don't work.
I do appreciate the help though!
Joe
