There is indeed a dimmer for the dash lights. Its one of the knobs up top on your display. I don't have my boxster with me at the office today or I'd try it and report back.
If you turn one knob all the way to the left or right and hold it there, it will flip the display over to KPH. No biggie, repeat the process to get it back to MPH. Then go to the other knob and your dash and dial lamps should get brighter or dimmer.
Now if this doesn't work, and you are certain your fuse isn't blown (did you test it properly, or just eyeball it?) then you may have to get it to a repair shop. One good fuse test is to swap out another of the same amperage in that slot that you know works.
Best of luck, and do report back as to what it was if indeed not a simple adjustment or a blown fuse.
