Are all parts you recently replaced OEM?
Common causes for these two trouble codes are the non-return valve or electric change over valve (you replaced this).
Do you hear the pump running after starting the motor (cold)? You should here a whine sound from the rear passenger side of the car for a ~minute after starting the motor.
You might have an electrical issue to the system/valves??
Jäger
300K Mile Club
